TwinTurbo.NET: Nissan 300ZX forum - I'll check it out. Would be surprised as the PCV Valves
MixManMash
on April 22, 2010 at 9:08 AM
TPS maybe or possibly PCV? Seems like you have checked
posted by 5280Z_nightstalker
on April 22, 2010 at 01:47 AM
were replaced 3-4 years ago.
Weird Idling Issue
MixManMash
09:57:23 04/21/10
Re: Weird Idling Issue
paintballkustoms
11:03:38 04/21/10
Thanks.
MixManMash
11:16:17 04/21/10
Re: Thanks.
paintballkustoms
11:23:53 04/21/10
Yes I have and the RPM does change. Sometimes it
MixManMash
11:42:24 04/21/10
Re: Yes I have and the RPM does change. Sometimes it
paintballkustoms
11:45:33 04/21/10
Yup, have cleaned all the connectors to no avail.
MixManMash
11:51:28 04/21/10
Re: Yup, have cleaned all the connectors to no avail.
paintballkustoms
12:21:37 04/21/10
I live in Edmonton, Alberta. (n/m)
MixManMash
13:00:53 04/21/10
What happens when you unplug the coolant temp sensor? (n/m)
HighPsi (NorCal)
12:20:11 04/21/10
Re: What happens when you unplug the coolant temp sensor?
paintballkustoms
12:23:06 04/21/10
I haven't tried unplugging the coolant temp sensor.
MixManMash
13:01:38 04/21/10
Re: I haven't tried unplugging the coolant temp sensor.
paintballkustoms
14:26:00 04/21/10
Done any work to the engine lately?
arkansasturbo
16:29:48 04/21/10
Nope. Nothing has been done recently. (n/m)
MixManMash
16:56:05 04/21/10
Hoping you could help me while I helped you.
arkansasturbo
17:24:03 04/21/10
Will definitely let you know what I come across. (n/m)
MixManMash
23:33:38 04/21/10
Did you use the fuel injector adapters?
inf
23:59:04 04/21/10
5280Z_nightstalker
01:47:30 04/22/10
I'll check it out. Would be surprised as the PCV Valves -
MixManMash
09:08:39 04/22/10
I submerged rails in water and pressurized the rail
arkansasturbo
18:22:43 04/22/10
